[Help]Which fan solution for c70
So I filled my c70 with 10 fans and now I put them from molex to a sata powered 1-8 hub and its still loud at 77db at the loudest part on the fans, is it a good idea to get a sata power resistor somehow or get some quiet fans with a fan controller built in
| CPURyzen 7 3700X & 2xE5-2680 V2 | Motherboard - Gigabyte X470 Gaming 7 Wifi & Dell Poweredge R720 |
| RAM - G SKill Hyper X 32 GB & 320GB ECC DDR3 | GPU - RTX 2080 Super W/ Block GTX 1060 6GB (R720) | Case - Metallic Gear Neo Qube (basically an O11D) | Storage - 2TB NVME + 8TB Unraid | PSU - Corsair RM650X Gold | Display - Samsung CHG90 49" | Cooling - Hardline EK CPU and GPU with 3x120 Rad | Operating System - Windows 10 Pro (PC) & Unraid (R720) |
https://linustechtips.com/topic/516181-helpwhich-fan-solution-for-c70/
Pics or diagrams of how it's set up please.
I would run them on the 5 or 7 volt rails rather than the 12 volt if that's what you're doing.
Also, what fans are these?
...lastly, why do you need that many fans?
Sig under construction.
how did you fit 10 fans in a corsair c70? also i would recommend getting a fan controller so you can control exactly how fast they are going
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
With the HDD cages installed, the only likely setup I can think of is 4 in the front, one on the bottom, two on the side panel, two up top, one in the rear. That's assuming he doesn't have an air cooler, either.
if you have to insist you think for yourself, i'm not going to believe you.
Well excuse the gts 250 I ordered a r9 390
I ordered a fan hub and it uses sata and pwm which is why it doesn't make sense as to why its so loud
Are all the fans pwm and have you adjusted their fan speeds?
Mostly voltage control I didnt want to put a fan controller and ruin the look of the front
I used a 1-8 pwm hub which helps and it is very slightly adjustable but still always loud
That's not what I asked..
