no aio is good there
just grab a criorig h7 and youll be fine
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
11/10 would not recommend an AiO for 60 USD. It's not worth getting an AiO over a more expensive air cooler if it's less than 240mm.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
So would it be worth getting something like an H100i GTX?
i like linux
Yes.
I put a Kraken X31 in my Spec-01. You can't go any bigger with the spec-01 or you have to remove the HDD bay. I can't even put a rad on top of the case because my Corsair Vengeance gets in the way.
AMD FX8350 Black OC 4.5ghz--NZXT Kraken X31--ASUS M5A99FX PRO R2.0--MSI R9 380 4G--Corsair RM750--Corsair 16GB Vengeance
Logitech G300--Roccat ISKU FX--Logitech Z623--HyperX Cloud II
If you absolutely need a budget AIO for your own personal tastes, H55 or Seidon 120v v2 are your best options. Perhaps even an x31 if possible.
I would recommend getting heatsinks for that price range though for pure performance.
Best Bench Runs & 24/7 Rig
Best Bench Runs
i5 4670k (XTU) - 4.7GHz Core / 4.5GHz Cache | GTX 980 (FireStrike Extreme) 1620MHz Core / 4000MHz Memory (GPUPI) 1721MHz | G.Skill Ripjaws X 2x4GB - 2200MHz CL10-11-11-24 1T
24/7 Rig & Clocks
i5 4670k 4.5GHz (Swiftech H320) | MSI Z87 MPower Max | ASUS GTX 980 1580MHz 4000MHz (NZXT Kraken X41) | 3x4GB Corsair Vengeance 1600MHz | Corsair Air 540 | EVGA Supernova G2 850w | 120GB Kingston SSD | 1TB Seagate Barracuda
Your case is very compact and unlikely to fit that cooler inside, Corsair on the website doesn't put the case as compatible with it unless you want to take the risk, so I would just get an air cooler since your case may not fit any 240mm AIO which are the only coolers worth getting for an Mid Tower case imo
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
yes
Rigs I've Built
