Best possible cpu cooler?
Go to solution Solved by Strom,
Noctua NH-D14 or NH-D15 the preformance jump from the D14 to the D15 is nothing to huge. and about the h110iGTX I have a H100i myself and I needed to change the fans because for my taste it was to loud (they are rocking some EK Vardar at 700RPM now) the noise of the pump is still driving my nuts (Im sorry I became a silence type of guy since last week).
because u have a R5 with a big air cooler u will be albe to keep the modi vents on and with the ULN (ultra low noise adapters) u won't be hearing ur CPU cooler anymore
Edit: I have an R5 myself with an AIO and my friend has an R5 with the NH-D14 and his is much quieter!
Seems like i'll get the NH-D15S if i can't do some ghetto modding with Liqtech 240  ;)
What is the best cpu cooler for upcoming amd zen cpus? My case is Fractals Define r5 and my budget is max 150€. My main requirement is silence and my current cpu is i5 6600k and cooler is Be Quiet! Shadow rock slim. Do i go for something like pure rock pro 3 or cryorig r1 universal or liquid cooling for example liqtech 240 (but i probably need to remove some moduvents and lose silence?
I'm Linus too. (:
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/
kraken X61 or H110iGTX
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6859972
I know that h1100i gtx is very  loud not sure about kraken and my main goal is silence.
its not if you change the stock fans
if you just want air cooling then get a NH-D15
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6859982
NH-D15 Blocks RAM ):
how about NH-D15S
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6860013
Edited by iBeast_M0de
CPU: R7 5800x -- Mobo: Gigabyte B550 Gaming X v2 -- RAM: 2x16GB Kingston Fury Renegade -- GPU: Asrock RX 6800 XT Phantom Gaming OC -- Case: Fractal Design North Walnut/Black Mesh -- Storage: 2TB 970 Evo Plus, 4TB NM790 -- PSU: BeQuiet Pure Power 11 Platinum 650w -- Displays: AOC AGON  AG352UCG, Dell Ultrasharp U2715H -- Cooling: Noctua NH-D14 -- Mouse: Corsair M65 -- Keyboard: Func KB 460 MX Blue -- Sound: Motu M2 -> THX 789 -> DT880 600Ω -- Mic: RØDE NT1-A
RIG 2: Intel i5-8400, 16 GB RAM, RTX 2070S
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6860030
you can raise the fan to avoid that...
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6860055
I'm Linus too. (:
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6860063
I have a Corsair H105, which is slightly different to the H100iGTX and can barely hear it, it also has a pretty decent pump in it and I've got no complaints as of  yet :)
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6860075
Yes you can, that's what I have. I recommend OP gets D15
i have one too and it fits with my tall corsair vengeance pro ram
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6860081
Are you not satisfied with your current cooler?
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6863344
Why won't they be using am4 so no current cooler my work
| CPURyzen 7 3700X & 2xE5-2680 V2 | Motherboard - Gigabyte X470 Gaming 7 Wifi & Dell Poweredge R720 |
| RAM - G SKill Hyper X 32 GB & 320GB ECC DDR3 | GPU - RTX 2080 Super W/ Block GTX 1060 6GB (R720) | Case - Metallic Gear Neo Qube (basically an O11D) | Storage - 2TB NVME + 8TB Unraid | PSU - Corsair RM650X Gold | Display - Samsung CHG90 49" | Cooling - Hardline EK CPU and GPU with 3x120 Rad | Operating System - Windows 10 Pro (PC) & Unraid (R720) |
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6877802
Noctua replaces mounting hardware for free for new sockets.
#NoctuaMasterRace
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/515796-best-possible-cpu-cooler/#findComment-6877828
