Is there anyway to decrease the stock intel cpu fan speed to below 1000rpm? Tbh it sounds so darn noisy to me in the new PC i built for my parents
I've tried setting min CPU fan speed (20%) to its lowest already (which is 20%) while setting the low limit temp to 50c
I tried using speedfan which doesnt seem to drop the CPU fan speed below 1000rpm either....
The CPU's a g3250 and it's hovering around 39-41c on idle
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/515759-cpu-fan-speeds/
What kind of fan header is it connected to? Is it 3 pin or 4?
4
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6859636
hmm. Odd. My guess was gonna be that it was using voltage control instead of PWM. But that's likely not the issue. Maybe you just got a crappy fan.
It's the stock cooler for intel xD
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6860099
What motherboard and SpeedFan settings are you using?
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6863973
Bios
Low limit temp = 50c
Low limit fan spd = 20%
Speedfan
0% for all temps on cpu
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6864486
Bios
Speedfan
Are those the only settings you changed?
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6864518
For speed fan i did tick the controlled speeds, change from smart fan to manual on advanced settings, and ticked the auto control spd
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6864528
Have you checked out the settings in the Speeds tab?
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6864569
Have you checked out the setting sin the Speeds tab?
Setting sin? Ive worked on speedfan with my main rig and it works perfecrly fine tho... Even tho the cpu fan doesnt go below a certain percentage of fan speed. The chasis fan do indeed turn off
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6864651
Settings in*
It was a typo.
Have you tried resetting the motherboard settings to default?
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6864732
Settings in*
It was a typo.
Ive tried all diff combination
(Default mobo settings, spd fan used)
(modified mobo settings, spd fan used)
(modified mobo settings, spd fan not used)
All of which doesnt allow the cpu fan to spin below 1000rpm (note it is a intel stock cooler)
Temp probe for cpu is working fine too (cpu idles ard 40c)
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6864900
Have you ticked the automatically variate box under the speeds tab?
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6865003
Yes
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6865065
Yes
Are you sure the cooler is plugged into the first cpu_fan header?
Is the fan speed stuck at ~1000rpm or does it just not get any lower?
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6865528
Yeap! It does not get any lower!
https://linustechtips.com/topic/515759-cpu-fan-speeds/#findComment-6867956
