Wireless mouse
Go to solution Solved by iM8Pizza,
General Use mostly. Like for coding and/or usual stuff and FPS/RTS gaming with a bit of MOBA. I prefer my mice small
Well, what us your grip? Do you prefer more than 2 side buttons? Or no buttons? Or even mooooaaaaaarrr buttons?
As for small.... well, small is relative... a Sensei can be small for my buddy but it can be big for other person, let's say.... compared to linus, is your hand bigger or smaller? Or perhaps it's around your hand size?
For mouse... the best thing you can do to find "the one" is by trying it, feel it... clicks it... move it around.... lift it up and down....
Well since you mention "general use", why not look into the Logitech MX Anywhere 2? It's basicly the little brother of Logitech MX Master... it's small and it is superb in any other factor, for comfort....well, it depends on... (look paragraph 1), and one more thing, for productive use, the MX excels on that (some people might disagree but most people agrees, it depends on taste anyway)
*EDIT: by "the MX excels on that" it's for the MX Master
Waddaya guys think? I'm looking for a wireless mouse because I'm gonna be using a laptop for a while and a wired mouse on a laptop can sometimes be a nuisance. I'm looking for a nice mouse that isn't glossy. Right now I'm considering the Razer Orichi. I also prefer my mice small. Any recommendations?
https://linustechtips.com/topic/515694-wireless-mouse/
Some suggestions I'd throw out there are the Razer Mamba, Logitech MX Master, Logitech G602, and SteelSeries Sensei Wireless.
2/4 that you mentios is considerably small, which is the Razer Mamba and the Sensei Wireless, the Mamba has problem with it's sensors, and the Sensei Wireless...it's basicly a Sensei with minor upgrade here and there...so Yeah.... (what are you going to use it for OP?)
https://linustechtips.com/topic/515694-wireless-mouse/#findComment-6859892
https://linustechtips.com/topic/515694-wireless-mouse/#findComment-6874243
https://linustechtips.com/topic/515694-wireless-mouse/#findComment-6886812
  • 3 weeks later...
Thank you, I think i just found what I needed. As for grips, I usually do Fingertip but sometimes switch to claw though not as often. I have small hands and using fingertip grip is most preferred and sometimes I get uncomfortable using big mice. I guess the MX anyhere 2 is a good fir for me.
https://linustechtips.com/topic/515694-wireless-mouse/#findComment-7016953
