does your cpu limit the speed your ram can run
im getting a i5 4460
CPU: i5 4690k  (overclocked to 4.3ghz)             CPU Cooler: Cryorig h7                 MOBO:  Msi Z97 pc mate             RAM: 8GB HyperX 1600 blue
GPU: rx480  4gb                                                 CASE: Corsair Spec-01 red              OS: Windows 10
PSU: EVGA 500   watt                                       SSD:    v60gb Mushkin ssd                HDD: 1000GB WD BLUE
https://linustechtips.com/topic/515670-what-determines-ram-speed/
As long as all of your ram is the same speed and your motherboard supports it (Would be weird if it didn't), you wont have any issues
so the cpu wont affect it
The memory controller on the CPU can limit the overclock the RAM can achieve, along with the motherboard.
