I have a Supermicro Motherboard which has a 8 pin connector. I checked the manual and it says the 8 pin power connector is required for the CPU.
However, the computer runs fine without connecting the power and only connecting the 24 pin power.
Is there a nugget I'm missing?
Does CPU need that extra power for turbo boosting or anything else?
https://linustechtips.com/topic/515556-8-pin-power-cables/
That is a must have connector for the motherboard, if the CPU is on higher load it can potentially draw too much current through the 24 pin connector alone. Also a bit odd since most boards theses days don't post without proper 8 pin EPS power.
https://linustechtips.com/topic/515556-8-pin-power-cables/#findComment-6857495
Yes. It works perfectly fine. Even in turbo boosting mode.
Oh, by the way my PSU can support upto 1200 watts. If that rings a bell.
https://linustechtips.com/topic/515556-8-pin-power-cables/#findComment-6858916
