Is this psu any good? How does it compare to companies like evga or Corsair
It's a high-end Seasonic unit that should outlive you :)
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6856594
The V750 is from Enhance and not Seasonic. It's still a great psu though.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6856645
The VS-series are Enhance and the V-series are Seasonic :)
EDITL Oh wait, gotcha this is a semi-modular unit
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6856675
The S add-on after the V is just an outside-US thing. They're the same unit.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6856695
ok so it will power a single 980 ti just fine how about if i drop down to the 650 watt model?
It's overkill. The 650w is still more than enough. I'd suggest bumping down to a 550w if it saves you money.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6857250
ok so pc spec wise i got
intel i7 6700k
gigabyte gaming 7 z170 mobo
gigabyte extremegamer 980 ti
samsung 850 pro 128 boot drive
seagate 2tb hybrid drive for storage
gskill trident 3200 ddr4 16 gigs memory
So really just looking for a power supply to power without having to worry. I dont plan on overclocking anytime soon. it was either the coolermaster v series or a evga power supply. so 550 watts would be fine for this?
i have it on pcpartspicker but the website wont pull up for me this morning.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6860489
intel i7 6700k
Yes, a good 550w would be plenty. If you would like a specific recommendation, it would help to mention where you're shopping.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6863490
Actually that would be great if I could get some recommendations preferable newegg but if I can find something better somewhere else it doesn't really matter where I buy it.
In the US?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6863936
Ok sorry had to figure that out haha yeah I'm in the us
A TS550 would be good: http://pcpartpicker.com/part/xfx-power-supply-p1550gts3x
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6865464
Is that just personal preference? I did a little research and xfx apparently make good psus however how do they stack against say coolermaster, evga, or corsair? The last xfx anything I had was a long time ago when they made geforce cards, so its been a while since I have looked at anything from them.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6870563
They're both called V-Series. It's just whether it's semi or fully modular. Semi is Enhance, full is Seasonic
"Rawr XD"
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6870581
All XFX are made by Seasonic. Cooler Master, EVGA, and Corsair power supplies are all made by different companies, so you can't simply compare brands. Some brands are better for different price points.
"Rawr XD"
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6870583
It's not so personal preference as it's one of the cheaper psus on the site that is still plenty for the system. If you personally prefer to spend more, feel free.
Cooler Master, EVGA, and Corsair all rebrand from OEM's and their quality range from mediocre to excellent because of different OEM's. XFX rebrands from solely Seasonic and have consistently good psus because of it.
There's no 'both'. The V750 and V750S are the same psu. The S is just left out in the US.
What are the top oem brands to look for seasonic being one, according to all the re iews on the coolermaster v series enhance seems to make a pretty good power supply what about super flower?
Super Flower is about as good as Seasonic. Delta is arguably the best.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6871810
Just an FYI, there's a new fully modular V series that had been release. The V550-750 are also made by Enhance Electronics like the semi-modular counterpart, and it has a smaller footprint than the Seasonic KM3 based V700 (150mm vs 170mm). There's also going to be V850-1200 from them as well, that will be rated as Platinum efficiency.
https://linustechtips.com/topic/515461-cooler-master-v750/#findComment-6872017
