PSU help
Go to solution Solved by WoodenMarker,
The model name is DR-8500BTX. I have seen some mixed reviews on Rosewill's products and I know to take parts on a case by case basis.
It's far from great of a psu but should still be plenty for your system.
@YellowRubberDucky
follow your topic
what psu specifically? i mean the 500w one
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/515327-psu-help/#findComment-6854761
Would it be beneficial to get a 600W PSU when I upgrade?
Nope.
https://linustechtips.com/topic/515327-psu-help/#findComment-6854765
I am moving my computer to a bigger case, with more fans
           my current build:
  • 500W PSU
  • Corsair H80i
  • 7850k Karavi
  • 16gb 1600
  • R9 270
  • SSD & HDD
  • Optical drive
Nope but depending on the 500W, it will definitely be beneficial to get a different PSU.  So I ask, what 500W is it?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/515327-psu-help/#findComment-6854779
A generic PSU that came with my case
I would definitely upgrade it to any Seasonic or XFX unit or an EVGA GS, G2 or GQ.
https://linustechtips.com/topic/515327-psu-help/#findComment-6854935
The power supply I believe is a Rosewill 500W power supply, it came with my original case
If it's branded from Rosewill, it probably isn't a generic psu.
What's the model name?
https://linustechtips.com/topic/515327-psu-help/#findComment-6854975
Yeah, that PSU isn't great. It's a generic unit branded under many different brands. Check out the PSU whitelist in my sig for some good PSUs
https://linustechtips.com/topic/515327-psu-help/#findComment-6863537
https://linustechtips.com/topic/515327-psu-help/#findComment-6863772
It's a generic PSU yo
The system has already been running with it though. The OP is just swapping cases.
https://linustechtips.com/topic/515327-psu-help/#findComment-6863911
Just because it runs doesn't mean it should :)
https://linustechtips.com/topic/515327-psu-help/#findComment-6864236
Thanks for the info and saving me about 60-100$ on a new PSU.
It's still a generic PSU, branded under many other brands that I have never heard of. I would highly suggest replacing it.
https://linustechtips.com/topic/515327-psu-help/#findComment-6871195
