Thoughts on this headset? Any suggestions on something better? :P
CoolerMaster Storm Scout 2 Black - Intel Core i5-4570 - CoolerMaster Hyper TX3 Evo - Sapphire Radeon HD7950 - Corsair Vengeance Pro 8GB - ASRock Fatal1ty H87 Performance - Seagate Baracuda 1TB HDD - Sandisk SSD Plus 240GB - Seasonic G-550 - BenQ GW2255 21.5" LED Monitor
2016 MacBook Pro 13" - Google Pixel
https://linustechtips.com/topic/51442-plantronics-gamecom-380/
Hey, I have this headset, its very good for the price you pay.
It's an on ear design but if you rotate the ear pads 90 degree's you can turn them into over ear :) due to the shape of the hole.
I wouldn't suggest personally anything else (headsets that is) unless you want surround sound or something.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/51442-plantronics-gamecom-380/#findComment-687009
I chose these for my brother's PC, I don't think you can get a better headset for the price although you could find some better headphones, it depends on how much you need that mic or whether or not you have another one. Ironically the previous version GameCom 367 was a little bit better in every way but slightly more expensive.
https://linustechtips.com/topic/51442-plantronics-gamecom-380/#findComment-687044
I need a mic haha, I personally have some el cheapo Logitech headset and they kill my ears! :P
https://linustechtips.com/topic/51442-plantronics-gamecom-380/#findComment-690087
