double graphyc card
Go to solution Solved by Billaviz,
Ok, Thanks!
Interesting, can you explain better? please!
If the cards are in SLI (so in your case, two 560Tis in SLI), all display connections must be to the "master" card, which is the card in the PCIe slot closest to the CPU by default. Any connections to the other card will not work.
If you disable SLI and just have the cards running independently, you can use connections from both cards.
https://linustechtips.com/topic/514075-double-graphyc-card/#findComment-6842451
last question, the two boards be may different model?
The GPUs must be the same for an SLI configuration, but the branding can be different. For example, a 560Ti put out by ASUS and one put out by MSI will work just fine together because they are both based on the 560Ti. But a 560Ti and a 760 for example wouldn't play well together. AMD is much more flexible in this area just FYI.
TUF GT501 | Ryzen 5600X | 32GB RAM | 480GB SSD | GTX 980Ti Hybrid | TUF X570 Pro
https://linustechtips.com/topic/514075-double-graphyc-card/#findComment-6844697
