So basically in the next few months I'm going to be building a new PC.
I'm not a hardcore gamer when it comes to quality, I play valve/source games like CS GO and Garry's mod. But don't know what I might play in the future when I have a capable PC.
I'd like the option to possibly stream/record/render. Not sure if I'll need it but might be a good thing to have.
SSD isn't an absolute need unless it helps with other stuff I want. I can wait an extra 10 seconds for startup. I'd be fine loosing it for performance somewhere else and less money.
...Yeah.
Had this suggested a few months ago http://ca.pcpartpicker.com/user/_Fire_Fly_/saved/GnHTwP
I changed a few things to see the price and have this http://ca.pcpartpicker.com/p/LpxHXL
I'd like to keep the price lower but can try to stretch it a bit. Probably no further then the $1190 mark.
I'm wondering
-Are the 970 and/or i7 worth the extra money.
-Can I get similar performance for cheaper.
-Can I get better performance for the same price.
-If I should just stick to the first build.
Also a place to get cheaper windows or something would be nice.
or if I can transfer my current windows(OEM) to the new PC.
I think that's everything, Thanks for the help.
Sincerely Firefly.
https://linustechtips.com/topic/514072-need-some-advice/
Top build should be more than enough,
The 970 isnt worth the extra but a 390 8GB is
The i7 isnt worth it, if you wanted to OC get a i5-4690k + Z97 board otherwise stick with the locked i5 + H97
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/514072-need-some-advice/#findComment-6842124
Alright, thanks Think I'll go with the 390 if not just sticking to the original.
does the model of 390 matter.
While you're here got any suggestions on a cheaper case still keeping the side panel window.
https://linustechtips.com/topic/514072-need-some-advice/#findComment-6842140
Your 4790K is overkill. It's also on a locked mobo. Here's a better build:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($280.00 @ Canada Computers)
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($103.99 @ NCIX)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ Canada Computers)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($403.99 @ Newegg Canada)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($97.05 @ Vuugo)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($89.98 @ Newegg Canada)
Total: $1205.20
Generated by PCPartPicker 2015-12-27 06:35 EST-0500
I've added a CPU cooler for overclocking and changed your SSD and PSU and switched the 970 for a beefy 390.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/514072-need-some-advice/#findComment-6842146
the 970 has the advantage of game recording. It depends on the software you use, some of them favors nvidias cuda. The i7 will only have a benefit while rendering
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/514072-need-some-advice/#findComment-6842147
Nope S340 is on of the best budget cases.
https://linustechtips.com/topic/514072-need-some-advice/#findComment-6842179
Here is a better build.
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($79.95 @ NCIX)
Memory: Patriot Signature 8GB (1 x 8GB) DDR3-1600 Memory  ($49.99 @ Amazon Canada)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($79.98 @ DirectCanada)
Video Card: Sapphire Radeon R9 390X 8GB Tri-X Video Card  ($479.88 @ Canada Computers)
Total: $1220.58
Generated by PCPartPicker 2015-12-27 06:46 EST-0500
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/514072-need-some-advice/#findComment-6842210
Total: $1205.20
Thanks. How hard would it to install the cpu cooler and ssd at a later time.
Alrighty, Thanks
Ok, Thanks.
i7 will also help with streaming.
i5 should be fine, especially if I OC.
Total: $1220.58
Thank you for the suggestion.
https://linustechtips.com/topic/514072-need-some-advice/#findComment-6842245
It wouldn't be hard at all. Just don't overclock until you get the CPU cooler.
https://linustechtips.com/topic/514072-need-some-advice/#findComment-6842259
