For the R4 I would probably go for a CM Seidon 240m just because it has a bigger radiator. But I would probably spend a little bit more to buy a h100i.
| i7 4790k | H100i | 16GB (8x2) Corsair Vengence | EVGA GTX 780 SC | ASUS Z97 Sabertooth Mark I | Samsung 840 120GB | WD 2TB Green x2 | Rosewill Hive 750W |
https://linustechtips.com/topic/51404-best-liquid-cooler/#findComment-686556
Are you in America?
If not try save a little bit more for a H220 or as said above the H100i
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
https://linustechtips.com/topic/51404-best-liquid-cooler/#findComment-686669
If you are looking for Asetek design, try LQ310 from zalman. Believe or not, this review says same performance as H100. and it's cheap..
http://www.hardwaresecrets.com/article/Zalman-LQ310-CPU-Cooler-Review/1697/6
Or you may try Silver Stone's or Zalman's new aio, they both claim using different technology.
https://linustechtips.com/topic/51404-best-liquid-cooler/#findComment-689539
