Hey, trying to follow this video by jackfrags to record some new gameplay but once I have everything set up correctly I get a message under the fps sign saying "INIT"
No clue what this is, I followed the video to the step and it still shows this.
Also please don't suggest shadow play, wasted me like 3 hours and I don't care about performance loss, I didn't buy a 980 6700K combo for no reason.
UPDATE:
FOUND OUT WHAT WAS CAUSING THIS!
The matrox codec was not working changed it to lagarith and now it works perfectly fine but I still want to know how to use the matrox codec :/
CPU: i7-6700K 4.7GHz GPU: GTX 980 STRIX 1337MHz CPU Cooler: H110i GTX AIO |
 Motherboard: Asus Z170-AR | Case: NZXT H440 White PSU: CS750W |
 PCPartPicker Link: http://au.pcpartpicker.com/p/43BkVn
https://linustechtips.com/topic/513956-dxtory-init-problem/
Shadowplay is actually really good so.... maybe just learn how to use it?
I can't get it working... It doesn't recognize cs go for me even when I launch it through geforce experience, its buggy asf. And when I press the according buttons ingame it doesn't do anything. If there is a way to get shadow play standalone great but I don't think there is a way.
https://linustechtips.com/topic/513956-dxtory-init-problem/#findComment-6840963
contact support? Nvidia support is surprisingly good.
https://linustechtips.com/topic/513956-dxtory-init-problem/#findComment-6847048
most people use OBS now..with nvenc
thats what you should be using
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/513956-dxtory-init-problem/#findComment-6847090
