Hello,
I have a problem with the frequenzy and voltages after OCing my cpu
Mainboard: MSI Gaming M5 (Latest bios included)
Cpu: 6600k (Chipset drivers installed)
I just moved back to Win7 from Win10, all updates installed (except the spy updates)
Now, I wanted to Overclock it again, and I set every single Bios setting as before, but now on Windows 7 I have constant max voltage and max frequenzy even when idling.
My OC Settings:
4,5Ghz @ 1,275V Stable
Bios tells me I have a max voltage of 1.288V
When I boot up, even after 5 minutes of idling in windows, I still have 1.228V and max frequenzy of 4,5 Ghz in HWMonitor
I set Core voltage mode to adaptive mode, just like before on windows 10.
Multiplier set to 45 in dynamic mode, also just like before.
As I said every single bios setting is the same when I had windows 10 installed.
On windows 10, when idling, my voltages and frequenzy was going down to the lowest numbers possible as it was supposed to be.
Now on windows 7 it stays at its peaks all the time.
Changing Power options from High performance to balanced does not work, even on power safer nothing changes
How can I fix that?
https://linustechtips.com/topic/513348-overclocking-problems/
Hello,
My OC Settings:
How can I fix that?
google: vdrop/vdroop/LLC
disable AERO on win7
Turn on in the BIOs "AMD cool and quiet", worked for me
with his intel CPU?!
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
https://linustechtips.com/topic/513348-overclocking-problems/#findComment-6835290
in win7, check power settings:
start>control panel>power options>balanced>advanced options>processor power management>minimum power state>5%
in the UEFI, verify all the c-states are enabled
I switched back to balance again, changed minimum power state to 0%, now everything works fine
Thanks for your help guys
https://linustechtips.com/topic/513348-overclocking-problems/#findComment-6835653
