First of all, im not planning a build. I did this to find out how people think.
So, long question, short.
You have a powerful main rig. You are going to LAN's fairly often.
In YOUR opinion, do your LAN rig need to be as powerful as your main rig?
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/513301-lan-rig-needs-and-wants/
Depends on the game and how competitive you are.
If you are playing tetris competitively you don't need a beast rig. A laptop will be fine.
If you are playing CS:GO you might need a decent card to run it at 144fps+ to get the most advantage.
If you are playing BF4 then you might as well carry your main rig.
https://linustechtips.com/topic/513301-lan-rig-needs-and-wants/#findComment-6834874
No, unless you main rig isn't the greatest to begin with and the cost of building a LAN rig that matches it is acceptable to you. Build the best LAN rig you can for you given budget
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/513301-lan-rig-needs-and-wants/#findComment-6834883
SG05 + mITX B85 + i5-4460 + R9 390 c:
That's one nice lan rig. I would of used the Lian Li PC-O5 ;)
Built  Not Bought
https://linustechtips.com/topic/513301-lan-rig-needs-and-wants/#findComment-6834943
That is so Correct ;)
Built  Not Bought
https://linustechtips.com/topic/513301-lan-rig-needs-and-wants/#findComment-6834946
no it just needs to play the games at smooth frame rates
That is right, though some people want over 60 fps.
Well. When i Think of a LAN, i Think that its more like sitting together and play games.
Built  Not Bought
https://linustechtips.com/topic/513301-lan-rig-needs-and-wants/#findComment-6834950
