tl;dr (So if you want the short question scroll to the bottom)
Pre-info: I'm in the Uk, my primary purpose is gaming, mainly AAA titles and a back catalogue of oldies. I want 60fps and my games to look tastier than your Christmas dinner.
Right...
I'll try and make this simple because I'm confusing myself.
My current rig:
FX 6300
Gigabyte 78LMT-USB 3
MSI R9 280
16gb Crucial 2x 8gb
120gb Sandisk ssd
1tb Seagate ST...over9000
550 watt Bronze 80+ PSU
Ok, cool. So I bought an i5 4590 a couple of months back and now I need a mobo. Simple right? Any H97. Or maybe a Z97 if I want to play with overclocking on another cpu later - which I want to do - so  that's narrowed it down to a Z97.
Then I thought 'hell I might as well get one with all the trimmings now so that I can just keep adding to it', so I narrowed it down to: this.
Sweet. Nice looking board, the future choice of either SLI or Xfire, M.2, etc...
I'm almost about to give Amazon my money then I see this.
Now herein lies my conundrum. Is the opportunity to have SLI in the future and M.2 worth the extra  £23?
Not only that, but by the time I get enough cash together to utilize either Xfire or SLI and an unlocked i7 and M.2, it will be late 2016 at the earliest. By then Skylake will be in full swing (using a different socket) and DX12 and Pascal will hopefully be ripping us all new assholes - in a good way.
So simple question now.
Which one do I buy? this. or this.
Merry Bethlehem
i7 6700k  ·  Asus Z170 - A  · MSI GTX 1080 FE  ·  32gb HyperX 2133  ·  2tb Toshiba 7200 Red  ·   120gb Sandisk SSD  ·   480gb Sandisk SSD  ·  Fractal Design Define S  ·  BenQ XL2730Z 144hz 1440 Freesync
https://linustechtips.com/topic/512865-z97-vs-z97-help-my-exploding-brain/
They can both run XFire.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
Right...
My current rig:
FX 6300
MSI R9 280
16gb Crucial 2x 8gb
120gb Sandisk ssd
Merry Bethlehem
get the 380 btw, the 280 is old :)
get the PC Mate because it also supports crossfire :)
Z97 vs Z97
both the same :D
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
Well. That PC Mate board isn't too great for overclocking if you're looking to do that in the future as the main reason for not going H97.
Although as pointed out they do have XFire and you currently use an AMD graphics card.
I think you should just buy a slightly nicer board anyway, that way it can't come back to bite you.
Although I would instead go for the Z97-AR over the Z97 Krait SLI
http://www.amazon.co.uk/ASUS-Z97-AR/dp/B00KDKUFAM/ref=sr_1_8?s=computers&ie=UTF8&qid=1451085431&sr=1-8&keywords=z97+sli
But either are fine, I just think the ASUS is better value for money.
nope, the pc mate one can't do SLI, but he doesn't have an nvidia card.
I changed it before you finished your post.
They can both run SLI or XFire.
I think the PC mate can only run Xfire...
The 280 is in the rig that I'm writing to you from now. This is just a mobo/cpu upgrade - and I already have the cpu.
Too fast for me :D
SLI in the future is a huge plus for upgradeability on a budget rather than spending a lot on a brand new GPU in the future. M.2 is also a huge plus if you want super fast PCIe storage compared to Sata 3.
I have the MSI Z97S SLI Krait Edition mobo. It looks good, performs well. Does not have a lot of features compared to MSI's other boards like their gaming series, but for me it gets he job done.
CPU: i5-4690k GPU: EVGA GTX 950 SSC RAM: 2x4GB Corsair Vengeance LPX 1600 MHz Motherboard: MSI Z97S SLI Krait Edition Case: NZXT H440 White
