So I've transferred all the data from my laptop to my new PC and it's wonderful, however, when I play Black Ops 3 (Only transferred game so far, it's on steam FYI) 'Campaign, Multiplayer, Zombies) is blacked out... Any idea why this is? I can't play it at all while it's like this. Here's a pic http://imgur.com/foNk6y1
Please help,
Many thanks,
vK
https://linustechtips.com/topic/512607-black-ops-3-problem/
Please help,
Many thanks,
vK
Verify the cache, also did you copy over the APPID?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/512607-black-ops-3-problem/#findComment-6828541
I have verfied it, I'll check now
EDIT: Where would I find it? Everything in the Steam 'Black Ops 3' folder I've copied
Its just before the common folder if i remember correctly
https://linustechtips.com/topic/512607-black-ops-3-problem/#findComment-6828579
That's just a bunch of appmanifests.
Yup that is what you want, copy the one with the id 311210 and put it in the same location on your pc
https://linustechtips.com/topic/512607-black-ops-3-problem/#findComment-6828589
I'll copy them all since I'll be transferring more games and they're only 1kb
Ok
https://linustechtips.com/topic/512607-black-ops-3-problem/#findComment-6828610
Done, I'll edit this after I find the result
EDIT: Still no success.
Can I team viewer into your pc again?
https://linustechtips.com/topic/512607-black-ops-3-problem/#findComment-6828621
