80+ and build quality
Go to solution Solved by alexhelvetica,
No, 80+ is the the rating of the efficiency and not quality.
Look at this list if you want to know what tier a PSU is in
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/512446-80-and-build-quality/#findComment-6827154
If a power supply is 80+ or higher, does that mean it's of good quality?
Nope! We have a topic pinned on this subforum about 80 PLUS efficiency.
https://linustechtips.com/topic/512446-80-and-build-quality/#findComment-6828015
