If you're stress testing the CPU with something like Aida64 you get a CPU load of 100% all the time. I did a 10 hour stress test on my CPU so i think there is no problem for your stream if the CPU runs at 80% load for a couple of hours.
Edit: I don't even know if there is something like damaging your CPU with constant high loads of like +70%. Maybe someone who knows better can answer this
CPU: i5 6600K | Cooling: Corsair H100i GTX | Motherboard: Asus Z170-A | RAM: 16GB HyperX Fury | GPU: Gigabyte GTX 980 Ti G1 Gaming (6GB) | Case: Phanteks Enthoo Pro | Storage: Samsung 850 EVO Basic (1TB) | PSU: EVGA SuperNOVA G2 (1000W) | Display(s): 27'' Asus PG279Q | Keyboard: Steelseries Apex M800 | Mouse: Steelseries Rival | Headphones: Beyerdynamic DT 990 Pro | OS: Windows 10 | PC Part Picker URL: http://pcpartpicker.com/p/WwL7zy
https://linustechtips.com/topic/511883-cpu-load-too-high/#findComment-6821431
Is it bad to have ur cpu running at a 70-80% load when streaming via OBS to twitch.tv??
How long can I have the stream going before it becomes unsafe? I don't want my cpu to break...
You can't damage your CPU by running high load for long durations, assuming your temps are OK and nothing like fans quit working.  Run a stress test for a couple of hours and see what your max temps look like, and that's the worst it will ever get assuming your fans don't quit.  I say "a couple of hours" as I've haven't seen a test running longer where the temps began to increase unless some external factor changed.
https://linustechtips.com/topic/511883-cpu-load-too-high/#findComment-6821468
You would need to run it with high voltage and temps to cause harm. CPUs are built for use. You could have it running 100% all the time for 5+ years and have no issues. What you should be asking is, why its only at 80%. One answer would be that you have i7 and rather low streaming settings.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/511883-cpu-load-too-high/#findComment-6827126
