My first PC build
Solved by Streetguru,
The Haswell based one is one that I'm particularly interested in
just about anything you buy is going to be outdated within a year or 2, the only thing you can future proof is like your case, and that's about it, maybe fans and your heatsink as well, I doubt SSDs are going to be outdated anytime soon aside from cheaper SSDs in the future.
the motherboard just had decent reviews and was cheap
ya, the 6600k has 5% more IPC, and gives you USB 3.1 but most people aren't going to need that really
pff, color sceme, performance per dollar above all else man.
