Digital Storm targets PC enthusiasts with exclusive HydroLux cooling solution. The HydroLux has High-flow pumps will push over 300 gallons of cooling fluid across the CPU and graphics cards every hour. You will have to pay a good 1,084
Let's suspend disbelief for a moment and pretend that you're willing to drop a grand on your PC's cooling system -- that's the kind of cash you'll need to set aside for the HydroLux from Digital Storm. The system combines liquid and air cooling, a control board and a bevy of sensors, along with custom software that puts you in command of your PC's thermals. High-flow pumps will push over 300 gallons of cooling fluid across the CPU and graphics cards every hour, which is augmented by an airflow system that can adjust dynamically, operate quietly or act as a wind tunnel. As a nice touch, you'll also find LED lighting throughout the rig that serves as a quick visual indicator of the heat levels within your PC.
The HydroLux is a new upgrade that's exclusive to custom PCs from Digital Storm, and it's available immediately across the company's desktop lineup. You'll pay $1,084 for single graphics card setups, on up to $1,994 for monsters that rock four GPU cards. Feel free to check out Digital Storm's website and peruse the system; you don't have to return to reality just yet.
Read moar here: http://www.engadget.com/2013/08/29/digital-storm-hydrolux-cooling-system/
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/51156-extream-cooling-hmm-maybe/
Crazy. Mine will be better.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/51156-extream-cooling-hmm-maybe/#findComment-683097
Not better than mine :P
Mine is filled with Chuck Norris' piss. FTW
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/51156-extream-cooling-hmm-maybe/#findComment-683167
that s a aio on a whole other scale...
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/51156-extream-cooling-hmm-maybe/#findComment-683512
This looks awesome
CPU: I7 3770k @4.8 ghz | GPU: GTX 1080 FE SLI | RAM: 16gb (2x8gb) gskill sniper 1866mhz | Mobo: Asus P8Z77-V LK | PSU: Rosewill Hive 1000W | Case: Corsair 750D | Cooler:Corsair H110| Boot: 2X Kingston v300 120GB RAID 0 | Storage: 1 WD 1tb green | 2 3TB seagate Barracuda|
https://linustechtips.com/topic/51156-extream-cooling-hmm-maybe/#findComment-684042
For being so expensive they should really put some more effort into the tubing not just have them loop around and cross over each other all over the place.
haha yea, the loop in the pic kinda seems rushed :)
Check out the build: Used to be Obot, now Lilith
Shameless: Me
https://linustechtips.com/topic/51156-extream-cooling-hmm-maybe/#findComment-684510
Wow this looks very advanced. But with that many tubes there might be a chance where a leak could happen. Like the LED thermal feature because it gives people how hot the system is running by looking at the leds.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/51156-extream-cooling-hmm-maybe/#findComment-684653
so 2000$ of ugly mess of tubes or save 2000$ for next gen gpus since stock 780 cooling is enough... tough choice... not
if you spend that kind of money at least make it look nice...
https://linustechtips.com/topic/51156-extream-cooling-hmm-maybe/#findComment-685895
