Haswell Cooling
Go to solution Solved by Guest GRRigger,
hyper 212 evo will drop it to around 70 degrees at load, and it will also decrease case temps
its around 30 euros
if you want overclocking, the one above is good, not to mention its reliable, quiet, very cool
Hi guys!!
I was playing FF14RR and had a youtube video running in the other monitor.Somehow i got to thinking about temperatures.I opened HWMonitor. And the core temps were 90'C.My idles are around 40'C.
I have the stock cooler.Inside the case it is around 30'C.Dust is not the issue,it's a new build.Now i need a new cooler.From a quality and price wise,what is the best? my budget is around 70 euros.
https://linustechtips.com/topic/51144-haswell-cooling/
Hi guys!!
http://www.amazon.co.uk/Noctua-Heatsink-Cooling-Dual-NH-D14/dp/B002VKVZ1A/ref=sr_1_1?ie=UTF8&qid=1377790507&sr=8-1&keywords=noctua+nh-d14 <----best air cooler on the market, be careful of ram clearance though.
https://linustechtips.com/topic/51144-haswell-cooling/#findComment-682889
