I just put together my first loop a few months ago and used EK coolant which says it contains biological inhibitors however when i was cleaning out my PC today i noticed what appeared to be algae growth in my resicour. How can i clean this out and what should i do in the future to prevent this from happening? thanks.
i7 4770k/Maximus VII Hero/Titan X/ 500gb 850evox2 r0/1000 EVGA G2
https://linustechtips.com/topic/510912-help-with-coolant/
you sure its algae?
what does it looks like?
it could be flux from not flushing your radiators before using them
https://linustechtips.com/topic/510912-help-with-coolant/#findComment-6811046
you sure its algae?
it's a spot on the side of the res it's greenish and a little cloudy around the area dark in the middle. I flushed them 3 or 4 times each with hot water
https://linustechtips.com/topic/510912-help-with-coolant/#findComment-6811074
you need to flush with deionised water, not tap water
that could be the reason
just empty your loop, run distilled water in it for a few days and clean any parts that you see algae on
also check inside your waterblocks to make sure there is no buildup
then refill it with fluid and see if it happens again
i dont think it will
https://linustechtips.com/topic/510912-help-with-coolant/#findComment-6811093
Even if microbes got in through the tap water, the biocidal agent in the coolant should have killed it off.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/510912-help-with-coolant/#findComment-6811134
yes it should have
idk why it didnt
if you want to try another coolant, mayhems has some very good premixes and concentrates
https://linustechtips.com/topic/510912-help-with-coolant/#findComment-6811136
