While looking for cases on amazon i stumbled upon the option to buy a case for the iPhone 5C!
http://www.amazon.com/Poetic-Atmosphere-Apple-iPhone-Gray/dp/B0093CDLM0/ref=sr_1_23?ie=UTF8&qid=1377755383&sr=8-23&keywords=iphone+5+case
AMD FX-8350 OC to 4.5ghz      Evga gtx 660       SilverStone FT03      Samsung 840 128gb
https://linustechtips.com/topic/51040-iphone-5c-case-leak/
Was the 5c the plastic ones?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/51040-iphone-5c-case-leak/#findComment-681340
Looks legit and with the updated OS too; quite excited for this actually ^_^
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
https://linustechtips.com/topic/51040-iphone-5c-case-leak/#findComment-681345
there's quite alot of stuff being leaked about iphone 5c and 5s right now.
Here's some for iphone 5c just look for some more in that website, I got lazy on looking for them.
http://www.jailbreaknation.com/a-closer-look-at-the-five-iphone-5c-color-options
http://www.jailbreaknation.com/iphone-5c-blue-red-yellow-green-white-unboxing
"Never invest money you're not willing to lose." -ImplyingImplicati0ns
https://linustechtips.com/topic/51040-iphone-5c-case-leak/#findComment-681354
Ya, there has been alot and SPIGEN and Poetic are leaking the cases. I think there is a way to order the backplates for the iphone 5s and 5c
https://linustechtips.com/topic/51040-iphone-5c-case-leak/#findComment-681366
