Hello, I'm upgrading my computer and I thought to keep my current power supply and graphic card
this is the computer I'm going to built:
cpu: I7 6700k(I will do OC)
motheboard: Asus Z170-A
Storage: 2x1TB Hard drive(SATA III)
memory: 2x8GB DDR4 2133Mhz
gpu: Gigabyte gtx770 2GB OC
case: nzxt phantom 820
pump:swiftech mcp655
radiator: 240(2x120)
and my power supply: seasonic psu 620w 80+
I need to replace to better power supply or it will be enough?
https://linustechtips.com/topic/510100-620w-will-be-enough/
More than enough wattage
https://linustechtips.com/topic/510100-620w-will-be-enough/#findComment-6801742
plenty of wattage.
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/510100-620w-will-be-enough/#findComment-6801752
https://linustechtips.com/topic/510100-620w-will-be-enough/#findComment-6801759
Okey, thanks
just according to this site:
http://outervision.com/power-supply-calculator#Basic
I need about of 670w :S
It'll use 300W under load with some overclocking so you should be OK
https://linustechtips.com/topic/510100-620w-will-be-enough/#findComment-6801780
Okey, I bought 620w then, becuase according to Gigabyte, its recommend 600w at least to the gpu
http://www.gigabyte.com/products/product-page.aspx?pid=4629#ov
Just saying, they recommend it but in reality it uses much, much less.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/510100-620w-will-be-enough/#findComment-6801835
