I have 2 disks: 850 EVO SSD and Toshiba DT01ACA100 HDD
I have a HDD activity LED on my case, however I seem to have connected it wrong as it is not working. I connected it to the motherboard F_I/O pins under '+HD-'.
Does it connect straight to the HDD (as it has a 2 pin connector) or is it somewhere else?
||| Drakon (Desktop Build) |||
|| CPU: 3800X || Cooler: Kraken X63 || Motherboard: B450 Aorus M || Memory: HyperX DDR4-3200MHz 16G ||
|| Storage: 512GB 970 Pro + 500GB 850 EVO + 250GB 850 EVO + 1TB HDD + 2TB HDD || Graphics Card: RX 5700 XT Red Devil || Case: Thermaltake Core V21 || PSU: XFX XTR 750W 80+Gold ||
https://linustechtips.com/topic/509789-hdd-led-where-does-it-connect/
It doesn't connect to your HDD (never has, never will, don't do it.)
Since it's an LED, you need to plug the positive plug into the positive pin and the negative into the negative one. You might have switched them
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
Refer your motherboard manual.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
