remount it and reapply thermal paste
https://linustechtips.com/topic/508629-4790k-temps/#findComment-6785064
It's below the max temp of the CPU, so it's fine. Although I think a thermal paste upgrade might help lower the temps a bit.
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
https://linustechtips.com/topic/508629-4790k-temps/#findComment-6785080
I'm at 1.19v on a h100i and can hit mid 70s when stressing. Curse Intel and their sloppy thermal paste jobs  :(
Depending on your motherboard the H100i can have an issue with a lack of mounting pressure, which may be the problem you have:
-https://www.youtube.com/watch?v=dEBzLQ6qYnc-
https://linustechtips.com/topic/508629-4790k-temps/#findComment-6785480
Already tried all these :) Makes no difference unfortunantely, I've just got a hot chip. Tried a Megahalems and 212 Evo as well and they couldn't keep it under 80c.
https://linustechtips.com/topic/508629-4790k-temps/#findComment-6785541
Hmm that's a bit unfortunate, I've seen 4790K thermal throttle on stock speeds with the stock cooler but that's a bit extreme.
https://linustechtips.com/topic/508629-4790k-temps/#findComment-6785565
