So I purchased some be quiet fans a while back and they were surprisingly louder then my $5 default case fans, I would have refunded them but it would have cost me $10 to send it back so I decided I would use them elsewhere. So I was wondering if there is some type of fan controller I can get to control the 3 pin be quiet fans because they're too loud for my liking and I would like to install them in my PC and put them to use but they're just too loud.
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/508157-fan-controller/
So I purchased some be quiet fans and they were surprisingly louder then my $5 default case fans I would have refunded them but it would cost me 10 dollars to send it back so I decided I would use them elsewhere. So I was wondering if there is some type of fan controller I can get to control the 3 pin be quiet fans I got because they're too loud for my liking and I would like to install them in my PC but they're just too loud.
If you have an external drive bay available, there are many options.
https://linustechtips.com/topic/508157-fan-controller/#findComment-6780035
Non-PWM be quiet fans?
If you're going to go there, just go all the way and drop 2$ more on the pwm skew xD
Anyway, there are a ton of 5 1/4" drive bay slotted fan controllers out there. A quick browse on pcpp will show you this, http://pcpartpicker.com/parts/fan-controller/#sort=a7&page=1
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/508157-fan-controller/#findComment-6780050
Also I only have two fan headers on my mobo would I need a splitter
Not with a controller. You plug the fans into that, not your motherboard.
Expansion bay controllers are manually operated. Something like the Grid+ by NZXT is an internal controller that you connect to your motherboard and control with software.
Choice is yours.
"A picture is starting to form here... I wonder if it's accurate? Some pieces don't quite seem to fit. Or maybe I just don't like the way it looks."
https://linustechtips.com/topic/508157-fan-controller/#findComment-6780075
