Main PC:
4TB Western Digital Black HDD (x3)
480GB Intel Series 535 SSD (x4)
8GB Kingston HyperX Fury (x4)
Corsair AX1000W Power Supply
Asus Maximus 8 Motherboard Hero
Intel i7 Skylake 6700K
GTX980Ti (x2)
Filco Wireless Mechancial Keyboard (x2)
SteelSeries Rivel Fade Edition Mouse (x2)
SteelSeries Qck Heavy Large (x2)
(Case undecided)
(Monitor undecided)
Server:
4TB Western Digital Black (x12)
480GB Intel Series 535 (x4)
8GB Kingstin HyperX Fury Ram (x4)
Corsair AX1500iW Power Supply
(Motherboard undecided)
(Core undecided)
(Graphics card undecided)
(Case undecided)
This build is to support duel play of one tower and does anyone have 144hz monitor suggestions? Also any suggestions for Cases for both server and main PC?
https://linustechtips.com/topic/507624-revised-build-thoughts/
Thanks :D just need to know do you think I can do the 2 pcs one tower with two 980tis? And a case to fit this all it :P
I worry that the 6700k might not be enough for what you want to do. In Linus's video he's using a 5960x (if i remember correctly) so 4 cores/system. In your build you're basically pairing an i3 with a gtx 980 ti... which is not terrible but not great either.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
https://linustechtips.com/topic/507624-revised-build-thoughts/#findComment-6774139
