Do those exist? I really wanna get those with my NZXT H630 which supports 2 200M fans on the top!
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
    Thermaltake Core V21
  • Storage
    1TB HDD, 700gb HDD, 320gb HDD and 256gb SSD
  • PSU
    Corsair CX600
  • Display(s)
    Flatron L1960TR , MAG MS776I , ViewSonic VA903m ( all of them are 1280x1024,dad found em) and a Fujicom FJ-32V TV
  • Cooling
    1 200M front fan, and unknowen CPU tower(low profile)
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
    Jamo E 4 CEN, Jamo E470 and Jamo E410 with a KENWOOD S505D
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/507425-aio-400m-radiator/
<internet bugged, double post>
The thing is I dont really want to have a gaint reservoir in my PC,whats a good solution to have those in my PC for the CPU?
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
https://linustechtips.com/topic/507425-aio-400m-radiator/#findComment-6772363
for a custom loop you dont have to get a huge res you can get away with a tiny micro res from swiftech but its a pain to fill sometimes . the largest AIO would be thermaltake 360 or ek's custom AIO setup at a 360mm . also 200mm rads are hard to find and the fans you would need ant cheap since you need static pressure fans
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
https://linustechtips.com/topic/507425-aio-400m-radiator/#findComment-6772858
