Been thinking about picking up a steam controller for a while.
Main thing I want to know is if it works decent for certain genres.
Mainly arcade racers
Games like Helldivers
Rocket league (arcade racer I guess?)
Some splitscreen FPS if I have a friend come over to my house
those are the main things I use a controller for right now, hence why I want to know if it's good for that!
Thanks guys!!!!!
I make bad life decisions.
https://linustechtips.com/topic/507397-steam-controller/
We only play zombies in Call of duty. So not competitive or too fast paced.
IDK if that helps or not.
As long as you don't care about being super accurate and dealing with the weird learning curve it'll be fine then in that setting as well :)
https://linustechtips.com/topic/507397-steam-controller/#findComment-6771489
ok
that's one of the main things I would use it for. But my friend would be using it, not me. Might as well think about other types of controllers as well.
https://linustechtips.com/topic/507397-steam-controller/#findComment-6771510
