yeah you can, but you will only have the minimum usable
so a 2GB + 4GB card = 2GB usable
https://linustechtips.com/topic/507045-need-help/#findComment-6767134
Amd clocks to the lower card stats and nvidia has to be the same card if im not mistaken
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/507045-need-help/#findComment-6767149
same model, not same vram
2GB 770 can go with a 4GB 770
https://linustechtips.com/topic/507045-need-help/#findComment-6767190
nvidia c**k block that move of 2GB SLi with 4GB
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/507045-need-help/#findComment-6767239
