Compatability problem!
Go to solution Solved by Amazingasian,
PC part picker is unable to verify if my Apevia X-SNIPER2-GN ATX Mid Tower Case and my Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler are compatible. Are they compatible?
Yes they are.
Yes they are.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/506845-compatability-problem/#findComment-6764795
Your case is 196mm wide.
The 212 Evo has a hight of 159mm.
So it should fit, considering the space behind the motherboard tray + standoffs is usually around 30-40mm. But don't quote me on that. I can not say for sure if it fits or not.
https://linustechtips.com/topic/506845-compatability-problem/#findComment-6764797
