I have an issue. (Don't we all)
At some point this week I will have a 7970 and a 7950 at the same time. I would love to crossfire them just for fun. Will a 750W Bronze Rated PSU be able to handle both of them.
I have;
x6 1100T (125W)
3 HDDs (60W)
2 SSDs (5W)
Watercooling pump (18W)
7950 (150W)
7970 (225W)
So that's a total of; 583W
Add 100W for any overhead so thats; 683W
Could someone double check those numbers for me; they seem a bit low?
EDIT: I based the GPU Power off the maximum theoretical power draw using the connectors provided.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/5065-power-consumption-crossfire/
Your PSU is just fine for OC'd CPU + Xfire + loop. Even if you do hit 750W from the wall, if you have a high end PSU (which I'm sure you do) it can go a little bit beyond that.
I don't have good experiences about going beyond the limit of a PSU.
https://linustechtips.com/topic/5065-power-consumption-crossfire/#findComment-58783
still ur 2e card wil most likely never draw full power at least ive never seen both my cards go full load 2e one does a lot less as far as i can tell
Appelzaadje - the Insane
Intel i7-4770K - Maximus VI Formula - Corsair Dominator GT 1866mhz - R9 290X - Xonar DGX - Samsung 840 Pro 256Gb - 3X WD1001FALS - Raven RV01 - Iiyama B2409HDS 3x - Custom water loop - Windows 10 Pro - XFX tripple monitor stand - Steelseries 4HD - Logitech G9, G19, G35 and Z5500
https://linustechtips.com/topic/5065-power-consumption-crossfire/#findComment-58789
your numbers are right.
according to techpowerup the highest theirs hit during furmark was
http://www.techpowerup.com/reviews/AMD/HD_7970_GHz_Edition/26.html
273 for the 7970 ghz
270 for the 7970
179 for the 7950
but those are only the very max that it ever hit,and it most likely never got close to that again.so you should be fine.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/5065-power-consumption-crossfire/#findComment-58870
