PC Upgrade help
Go to solution Solved by DarkBlade2117,
Thanks, I'll try to get a new PSU first then go for the CPU I guess.
Get something like a 520w Antec High current Game or a EVGA B2 Series, if you have more of a budget get like a 550-650w EVGA GS or G2, even a GQ or any XFX or SeaSonic PSU.
Then for the CPU look into a i5-4460 or if you plan to do like video editing and recording a Xeon 1231v3 for around $230 will be much better.
So, I'm planning on upgrading my PC soon. Just a bit confused which I should prioritize first since I don't have a lot of cash and parts are pricey where I'm from.
I use this mainly for playing games, work and minor video and photo editing.
My PC specs are as follows:
CPU: Intel i3 4170 @ 3.70GHz
GPU: GTX 960 Inno3d Herculez X2 2GB OC
MB: Asus H81M-D
RAM: Kingston Hyper X 8GB DDR3 1600mhz
PSU: Huntkey 400w True rated
HDD: 2.5" 500gb Seagate
I just used my old laptop's hdd since it still works fine. I would appreciate it if you guys could tell me which part I should prioritize and why. Thanks!
"Dreams worth more than money."
https://linustechtips.com/topic/506304-pc-upgrade-help/
MB: Asus H81M-D
ive never heard of that psu, a more reputed brand for that maybe a good idea...
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6757883
CPU definitely. Get a quad-core i5 if you can, or an 8-core AMD (FX series) if you don't have the budget. Second priority should be the PSU.
  Christian
Use the following style specs in your sig to spread the LTT revolution!
Rig Specs:
Screeninator: Gigabyte GeForce GTX960
Powermathingy: Corsair CX600W
Stickiminator: 2x G.Skill ARES 4GB DDR3-1866
Procrastinator: AMD FX-8350 @4.1GHz 1.3V
Holdametalicizor: DIYPC Gamemax-BK
Noisoundacreator: Cyber Acoustics CA-3072 (loudamagargle) Onn Wireless FM Radio Headset (earamagargle)
Attachamathingy: ASRock 990FX Extreme9
Remembrerthing: Western Digital 1TB Blue, Western Digital 40GB Blue
Flat-Colorful-Thing: Acer K272HL
See-A-Move-O: Logitech Hyperion Fury G402
ButtonBoard: Cooler Master CMSTORM Devastator Blue
Talkamagargle: Blue Snowball Ice
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6757889
SSD will make the biggest impact on day to day use. I would also get a better power supply too since I don't know that brand. From there upgrade depending on your needs. Ex: i5/i7 processor, more RAM, etc.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6757894
Better processor will help with gaming as well as video rendering. It should come before an SSD which isn't that necessary when he has an i3 dual core.
  Christian
Rig Specs:
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6757898
Yeah, to be honest I never heard about this PSU too when I got it. The CPU is one of my top choices so far, just need to save up a bit to get an i5 I think.
For the storage, is there really any difference if I just keep on using the 2.5" instead of a 3.5"?
AMD at this price point can offer better performance
But that would mean I need to replace the motherboard too :(
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6757914
Storage should be fine. Size doesn't really matter.
Just save for an LGA1150 i5.
  Christian
Rig Specs:
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6757945
How about the motherboard? Any reason I should consider upgrading? I know the one I have is very entry-level. I should get a new PSU too I think, don't wanna blow this pc up due to some unknown PSU.
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6757968
If your PC is just for general use as you say, you should be good. If you want to OC or something big like that then I would consider an upgrade. As of now it's fine.
  Christian
Rig Specs:
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6757979
Alright sounds like a plan. Go ahead and mark the post as resolved if you're okay (helps the mods out a bit).
  Christian
Rig Specs:
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6758037
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6758040
I might get the seasonic one since I think it's a bit cheaper. For the CPU I'll look into the prices of those 2 since it's a bit expensive where I'm from.
Thanks, will do just that. :)
PSU... My order to upgrade personally would be: PSU, CPU, SSD, MOBO, then GPU last b/c that gpu should last a while
Yeah it's definitely what I'm going to be doing.
Thanks for all the help guys, really appreciate it!
https://linustechtips.com/topic/506304-pc-upgrade-help/#findComment-6758263
