60?
That for an intel CPU tho.
kinda universal really, only difference is that for Intel that's the advised limit/constant temp, while well under the actual limit. meanwhile for AMD that's hovering just under throttling point
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/506295-good-cpu-temps/#findComment-6757844
Below 30 for idle, and 60 for full load, the max it can handle is about 65... someone should check that, but it really depends on your comfort zone
For mine i was getting about 40 for idle and 70 for load. ill try again though
Breaking things 1 day at a time
https://linustechtips.com/topic/506295-good-cpu-temps/#findComment-6757857
Using Open Hardware Monitor ive seen temps as low as 33.1 and as high as 50.6 in idle at 4.7Ghz (avg 41.85) over a 10 minute span
That's sounds pretty good to be honest, you can try to let it build up a bit more but I would be happy with that.
fx-8320 wiht a Raijintek Triton
How's that working out for you, I wanted to get one, after watching linus's review, but there were many complaints relating to damage during shipping on Newegg ...
https://linustechtips.com/topic/506295-good-cpu-temps/#findComment-6758032
Lazy review: Color leaves quickly. Works great so far though
Detailed Review: Well the color (mine was pre-filled with blue) is nearly all gone and i recieved it 12/9/15. Also its mounted really badly in my case. (Thats my cases failt. Im getting a NZXT H440 soon). Fans are a little cheap since they are controlled by that knob thing but it gets the job done. I made a cool marker thing on my case for it.
Overall besides the cooler its working great. I plan to refil the loop in about 2 weeks and put on a triple radiator sometime
https://linustechtips.com/topic/506295-good-cpu-temps/#findComment-6758060
60?
New Thermall Paste? Those idle temps seem really high for a cpu at at like 6% on only 1 core
https://linustechtips.com/topic/506295-good-cpu-temps/#findComment-6758087
hmmm, interesting, my h60 is working well for the time being so i guess ill hold off on it until something more compelling pops up in the aio market (my case is too small for custom watercooling)
Ok load results are in. it averaged about 63-65 degrees and hit a max of 71.6 in Aida64.
That's not too bad at all, just on the edge of safe temp levels. Personally i would try to get the fans going a bit faster, or swap fans to get nearer to 60 though
https://linustechtips.com/topic/506295-good-cpu-temps/#findComment-6758092
New thermal paste can help, I've seen a really wide range of values for idle temp so below 30 encompasses all of them. Ideally, it should be colder.
I guess i put on to much before. Now idle is hanging around 33-40 with a max of 45.8
https://linustechtips.com/topic/506295-good-cpu-temps/#findComment-6758567
