Heyo,
I just recently ordered a Noctua NH-D15 which I was really excited for. I moved my system into a new case which is the Corsair Carbide 100R Mid Tower.. Unfortunately, the cooler is too tall for that case, so I had to send it back. Any recommendations?
What my CPU has to handle:
I would like to overclock the CPU a little bit. I already know that it can handle all I need it for. It would be able to handle streaming and recording (in the same time) at 720p 60 FPS if it wasn't for thermals making me feel uncomfortable. It hits about 68°C when I decide to record the gameplay while I stream it, which I am really not okay with and stop shortly after. But performance wise, the CPU would handle that just fine, I could tell.
Other than that, it also has to be able to handle rendering lots of videos. An overclock would help me crank up CPU intensive games and still be able to record them at 1080p 60 FPS without a lot of stuttering, I hope. For that overclock I need better cooling.
It doesn't necessarily have to be an aircooler, I just need the system to the reasonably quiet (which is the reason I moved it into a new case with better fan mounting options and some other modifications to keep it silent) so an AiO watercooler is not that benefitial, as many people said the pump and fans together create a fair bit of noise.
Hit me with your recommendations, please.
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/
Hyper 212 EVO is a really popular choice. Alternatively, I used the Hyper D92 with my FX 8350 and it served me well; fairly silent though thermals weren't super impressive with the included fans. I think you can take the heatsink of either of these and add on some custom fans, so get some custom 92mm ones and you're good.
  Christian
Use the following style specs in your sig to spread the LTT revolution!
Rig Specs:
Screeninator: Gigabyte GeForce GTX960
Powermathingy: Corsair CX600W
Stickiminator: 2x G.Skill ARES 4GB DDR3-1866
Procrastinator: AMD FX-8350 @4.1GHz 1.3V
Holdametalicizor: DIYPC Gamemax-BK
Noisoundacreator: Cyber Acoustics CA-3072 (loudamagargle) Onn Wireless FM Radio Headset (earamagargle)
Attachamathingy: ASRock 990FX Extreme9
Remembrerthing: Western Digital 1TB Blue, Western Digital 40GB Blue
Flat-Colorful-Thing: Acer K272HL
See-A-Move-O: Logitech Hyperion Fury G402
ButtonBoard: Cooler Master CMSTORM Devastator Blue
Talkamagargle: Blue Snowball Ice
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6757657
i think a coolermaster GeminII S524 Ver.2 would be a solid choice
jayztwocents used it recently and as he pointed out it keeps
the northbridge and the vrms cool as well
HAF-x,  silverstone op1000, 4670k 1.28v 4.3ghz,  gigabyte g1 sniper z87,  gskill ares 1866 2x4gb,  EVGA gtx 970 FTW 1518/7800, ocz vertex 4 128gb, seagate SSHD 2Tb
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6757949
I've tried to look this cooler up. I saw it in Jayz' video aswell, but it seems like it is not available for purchase in my region yet. Really strange. Amazon nor caseking can find it in the search.
Do you have any numbers for me under load for either the Hyper 212 EVO or the Hyper D92? It does sound tempting if it really is as silent as you say.
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6760559
Use http://de.pcpartpicker.com/ and put your case and motherboard in the list and it'll tell you all the coolers that will fit. Also, the be quiet! Pure Rock is basically a quieter 212 EVO and is better in thermals iirc.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6760637
Why are you concerned about 68°C? That's almost 30 degrees headroom to max.  Are looking for performance on par with a D15? The only way you'll get that in a smaller package is with an AIO cooler. I use a Pure rock in my system and it's dead silent and gives me great thermals (running at stock speed until I figure out how to OC (PMs welcome!)) under aida 64 I only hit ~55°C. With the stock cooler I was hitting about 90°C.
CPU: Intel Core i9 9900K GPU: Gigabyte AORUS GTX 1080Ti 11GB RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Motherboard: Gigabyte Z390 AORUS MASTER PSU: EVGA SuperNOVA G3 850W 80+ Gold Storage: Samsung 970 Pro 512GB M.2 / Samsung 860 Evo 2TB 2.5" CPU Cooler: Corsair H150i Pro Case: Lian Li Lancool One
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6760979
I personally don't feel comfortable with temperatures above 65°C. Especially in longer sessions when I stream for 5 hours+, record games for half a day straight or spend 3 hours rendering a video. I'd prefer to keep the temperatures as low as possible.
The beQuiet! Pure Rock actually looks really neat and affordable, I'll strongly consider that one when making my choice. Thanks!
Bookmarked that page, thanks! Also thanks for the recommendation.
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6761542
If you want temperatures below 65 C om an 8350 you need something like these: http://de.pcpartpicker.com/part/noctua-cpu-cooler-nhc14s or http://de.pcpartpicker.com/part/silverstone-cpu-cooler-ssthe01
USEFUL LINKS:
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6761594
The pure rock won't give you the kind of cooling performance you're going to need if you want temps that low under load, especially under an over clock.  The pure rock is a budget cooler, in line (but slightly superior to) a Hyper 212 EVO.  Entry level cooler if you will.  You need a top tier dual tower cooler (which apparently won't fit your case) or water to keep temps as low as you're asking.
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6761638
I can't seem to find how either of these perform on an 8350, do you happen to have any reviews or something at hand?
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6762185
No, it's just large coolers like that can't possibly let the temps exceed 75 deg. Plus, why are you so keep on below 65?
USEFUL LINKS:
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6762213
That's like the sweet spot for FX chips.
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6762326
I'm using a single tower right now (Scythe Katana 3000) and I've never been past 70, let alone 75. That's without an overclock, though.
Pretty much that.
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6763175
This one. I got one coming this week for my 5820k.
I7 5820k, Asus X99 Sabertooth, 980Ti Classified, 32gb Gskill Ripjaws 4, Corsair Rm1000i, Samsung 950 Pro, Custom Loop Xspc Cpu Block Ek Gpu Block, Windows 10, Define S. Acer Predator XB271HU
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6763714
This or the 212 Evo but if you pick Evo get a VRM fan! :D
What I personally did:
Piledriver-Tux / Vishera-X8-8370 = Case: Cooler Master HAF XB Evo Black / Case Fan Rear: SUNON MagLev KDE1209PTV3 92mm / Case Fan Side: AVC DS06025R12U 60mm / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 Black Edition (4.5GHz) Octa-Core / Display: ASUS 24" LED VN247H (60Hz) / GPU: MSI GeForce GTX 970 (1216MHz) 4GD5 OC "Afterburner" / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Logitech Desktop M120 / PSU: Cooler Master V650S, 650W PSU / RAM 1 & 3: HyperX Savage DDR32133MHz CL11 4GB (2x4GB) / RAM 2 & 4: Patriot Viper III DDR3 2133MHz CL11 4GB (2x4GB) / Operating System: Ubuntu Kylin 14.04 LTS / Operating System 2: Windows 10 Home / Sound: Logitech Stereo Headset H110 / Storage: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate Barracuda 2TB HDD / Wifi: TP-Link TL-WN951N 11n Wireless Adapter / http://pcpartpicker.com/p/tNjNt6
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6764714
the biggest problem you are going to face is the 150mm height restriction with that case
my mate has a 8350 and they do run toasty without a decent cooler
i gave him my h100 which has tamed it as he has a narrow case similar to yours.
if your set on air cooling id go big with a Noctua NHC14 or the forementioned coolermaster GeminII S524 Ver.2
or look at a aio liquid cooler a h80i or equivalent at idle they are a litte noisier but under load much the same as a air cooler
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6802199
Do you happen to have some reviews or numbers at hand? I'd really like to know how these coolers perform on an FX 8350 under load (the GminII S524 is still not available in my region).
https://linustechtips.com/topic/506221-solid-cooler-for-fx-8350/#findComment-6808188
