Have you tried looking up "imac g3 builds" or "...mods"?
EDIT: @Mattsoup Make sure you always follow your own posts.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/505876-imac-g3-case-build/#findComment-6752140
If you can do something like this then it should give you plenty of room to work with for internals.
https://www.youtube.com/watch?v=0eGoFGwveNU
END OF LINE
https://linustechtips.com/topic/505876-imac-g3-case-build/#findComment-6752167
I wasn't even on the site, i wouldn't have seen the alert
It's still expected that you always follow any threads that you start, at least until you question is answered/the conversation is over, just so that you know when people reply. Not everyone uses quotes (as I didn't above, even though I generally do) so if you're not following your thread then you might not know when someone replies. Just a friendly FYI. :)
END OF LINE
https://linustechtips.com/topic/505876-imac-g3-case-build/#findComment-6752304
