Needs some advice for PC building
How about the Seasonic M12II 550 Watts 80 plus bronze efficiency.
I wont be able to afford crossfiring right now and my monitor is kinda shitty as it is (I bought it without researching dumb me)..
I mostly play games so would 8gb of RAM be enough? although 16gb wont be a problem DDR4s are pricey right now.
and oh what do you recommend about the Cooling system? would stock CPU fans and Corsair 760t fans do or do I need an upgrade?
The 550W M12II is a great unit.
A single 390X is fine, a 390 is fine, a 970 is fine. All great cards.
A single stick of 8GB is fine if it puts money towards other parts.
Stock cooling is fine if it puts money on other parts.
The Corsair 760t is not a cheap case. Do you have cheaper options? The Phanteks Enthoo Pro ($99 USD/$140 CDN) is much cheaper here, but just as well built as the 760t, maybe even better quality.
