Hello guys,
i want to build a pc as fast as possible because my laptop is very old and i need something to game and work on.
The following build is the one i thought of:
CPU:I3-6100 Skylake 3.7 GHZ
GPU:VTX3D R9 380 4Gb
Mainboard: Asus H110M-A
RAM: Team Groups Elite Plus Series Black DDR4-2133  8GB
PSU: Corsair VS450 450 Watt
Case:BitFenix Nova Midi Tower
If you can leave a comment ,i would thank you :D
PS:Sorry for my bad english :)
https://linustechtips.com/topic/505464-help-with-my-new-pc/
Get a better PSU and that build is fine.
i5 6600K @ 4.4GHz / Cooler Master Nepton 240M (GC Extreme Thermal Compound) / Asus Maximus VIII Gene / 8GB Corsair Vengeance LPX DDR4-2400 / 240GB SanDisk SSD Plus & 2TB SeaGate Barracuda HDD / EVGA GTX 980 ACX 2.0 / XFX XTR 750W 80+ Gold  / Fractal Design Node 804        Total: £1042.31
https://linustechtips.com/topic/505464-help-with-my-new-pc/#findComment-6746602
I don't think that PSU will be enough for your build. Use pcpartpicker to check.
i7-7700 | Asrock H270M-ITX | Fractal Design Core 500 | 16GB Corsair Vengeance LPX | EVGA GTX 1080 Ti | 850 EVO 500GB | 850 EVO 250GB | WD CavGreen 2TB
EVGA SuperNOVA 550W | Steel Series Elite Prism | Final mouse 2015 | WASD Keyboards V2 (MX Blue) | Acer Predator 1440p 144Hz
https://linustechtips.com/topic/505464-help-with-my-new-pc/#findComment-6747561
The pcpartpicker says that i have a power consumption of 320 W
Should be fine then ¯\_(ツ)_/¯
https://linustechtips.com/topic/505464-help-with-my-new-pc/#findComment-6753538
Hello guys,
If a haswell i3 is significantly cheaper go for that
Otherwise look for a 550+ wattage PSU so you have plenty of headroom and the PSU isn't going to be very stressed
https://linustechtips.com/topic/505464-help-with-my-new-pc/#findComment-6754670
Instead of going Skylake, you could get a Haswell for cheaper, similar performance. Also you would be able to use DDR3 over DDR4 for more cost savings. You can use the money saved for a cheaper build, or put the money back into the computer and get a better i3 or i5, gpu etc.
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
https://linustechtips.com/topic/505464-help-with-my-new-pc/#findComment-6754910
