Laptop without air intake vents
Srock97
HP laptops have no air intake vents . only one hot air blow vent at right side.
does it's bad ?
Why HP make such models
if the laptop is new then the its a thermal design you dont really need air intakes but most of the time it sucks in air from the keyboard.
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
usually it either sucks ar in through the keyboard, or it has a vent on the bottom where it sucks in air.
honestly, they wouldn't bring out laptops with this design if it didn;t work. have a little faith in the manufacturers!
hp tends to put their intake in strange places, my hp laptop has its intake under the "Z" key (or "W" for the qwerty folks)
guess what happens when playing games xD
the intake is underneath the keyboard
My old laptops microphone was on the keyboard.
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
on mine it was on the wrist rest, guess where in comparison to my hand xD
