Wattage issue.
Go to solution Solved by Bluejay0,
I'd grab an 800 Watt for SLI/Future proof
750
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/50520-wattage-issue/#findComment-673683
750 or 850 to be safe. Honestly probably wont pull more than 520-570 out of the wall, but 750 is good overhead.
https://linustechtips.com/topic/50520-wattage-issue/#findComment-673687
I'd grab a 80+ 700/750W power supply.
"And yet my mind is screaming, provoked in an icy sweat. It’s pleading and begging for a release, scraping the walls of a padded cell, pounding hopelessly at the floors that won’t even deliver the gift of pain."  - Why I Don't Dream Anymore
https://linustechtips.com/topic/50520-wattage-issue/#findComment-673690
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/50520-wattage-issue/#findComment-673693
A 700w is plenty.
https://linustechtips.com/topic/50520-wattage-issue/#findComment-674678
