Will a 24+4pin power supply work on a 24pin mobo? Im confused what the difference is between a 24pin psu and 20+4
My rig: Case: Corsair 760T CPU: Intel 4690k MOBO: MSI Z79 Gaming 5 RaM: 16gb HyperX SSD: 256gb Samsung pro HDD: 1tb Toshiba PSU: Thermaltake smart 750 GPU: 1x GTX 1080 Founders edition
https://linustechtips.com/topic/50511-power-supply-question/
there is no 24+4pin :)
it is 20+4 and all current gen MoBos use 24 pin connector.
And if you have some old 20pin MoBo 24pin will still work.
https://linustechtips.com/topic/50511-power-supply-question/#findComment-673536
Even running only a 20pin in a 24pin mobo will be fine
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/50511-power-supply-question/#findComment-673543
Sorry did mean 20+4 typo :P so it would work alright on a 24pin board?
https://linustechtips.com/topic/50511-power-supply-question/#findComment-673634
