H100i GTX power cable / how to connect
Solved by The_Sandman,
So I think i found the best solution for this:
- Cooler-Fans go into the H100i GTX's splitter cable
- USB-cable from the pump go to a USB header on the motherboard
- 4-pin power cable from the H100i GTX goes to the CPU_Fan header (as described in the manual)
- Fan-Hub (with all Case-Fans plugged into it) goes to the CHA_Fan4 header on the motherboard. (In the motherboard manual on page 25 it says that the CHA_Fan headers support PWM)
Can anyone tell me if this will work?
Edit:
Figured it out myself, it worked fine for me the way i mentioned above. So problem solved
