This is my first PC build so there is somethings i am not sure about, so i will explain them as good as i can. HERE WE GO!
-what is TDP?
-What is the correct order when assembling the PC?
-How do i overclock my CPU and my GPU? And is it necessary?
-I5 or I7?
-Is anti static wristband needed?
And these are my specs.
http://pcpartpicker.com/p/RLsvBm
I will board the pirate boat and sail the illegal seas for WIN 10 so no worries there :D
LAST QUESTION: Are the specifications compatible?
NOTE: this pc is made for gaming.
Edited by Godlygamer23
https://linustechtips.com/topic/504652-first-pc-build/
let me fix your build and save you some trouble
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736266
If you want to overclock get a K processor like the i5 6600K, the i5 6600 doesn't overclock.
Don't get the V300 get a BX100, the v300 is bad it had its controller replaced with a slow one.
The 970 gets beaten by the r9 390 in high resolutions so you may want to consider it.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736271
do you own the PSU already?
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736276
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($19.89 @ OutletPC)
Motherboard: ASRock H170 Pro4S ATX LGA1151 Motherboard  ($93.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($53.99 @ Newegg)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($61.49 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.88 @ OutletPC)
Video Card: Sapphire Radeon R9 390X 8GB Tri-X OC Video Card  ($368.98 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($63.99 @ SuperBiiz)
Power Supply: XFX TS 550W 80+ Gold Certified ATX Power Supply  ($59.00 @ Amazon)
Total: $987.20
Generated by PCPartPicker 2015-12-13 12:11 EST-0500
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736281
yes when you use pcpartpicker they are
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736286
Total: $987.20
This, go with this.
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736288
-what is TDP?
Thermal power design, or how much heat a component gives off
There really isn't one, but watch Linus' build guides to get an idea
You overclock by increasing the multiplier and voltage in the BIOS for the CPU and use programs like MSI afterburner for GPUs. Overclocking is not necessary
-I5 or I7?
For gaming, i5. Most games use less than 4 threads, so the eight threads on i7s are not utilized.
-Is an anti-static wristband needed?
No, just periodically ground yourself by touching the PSU and avoid building on shag carpet. (Firm carpet is better as there is less of the chance you will generate static electricity)
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736376
I have no pc parts
then go for the build I posted
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736379
-what is TDP?
-I5 or I7?
NOTE: this pc is made for gaming.        attachicon.gifDOGE.jpe
Get a 1TB hdd for more storage 120GB isnt gonna get you far.... i7!
                             Current PC Specs
                       GPU: 750ti CPU: AMD FX-6300 PSU: EVGA 500W Case: Corsair Carbide Series Windowed 100R Mobo: Gigabyte GA-970A-DS3P
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736422
Deep down inside everyone is a pirate.
Speak for yourself friend :P
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736427
-what is TDP?
-I5 or I7?
1. TDP is how much heat energy (NOT power consumption) that a processor or component will emit at full load. High-end cards will be between 150-300W.
2. Assembling a PC should be in the following order -
- Open case, insert power supply, wire the cables through the case.
- Insert I/O shield (included with the motherboard) into the cutout in the case. Insert the motherboard,
- Hold the motherboard in place by a VRM or chipset heatsink and screw in one of the screws as a pilot, then screw in the rest. IMPORTANT make sure there are motherboard standoffs beforehand.
-Insert the CPU into the socket, pull down the retention bracket.
- RAM
- Cooler
- Sata Cables
- Graphics card
- Hard drives
- Fans
Then you're pretty much good to go
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736459
My dad has a 1TB HDD :)
get a new one - HDDs live around 4 years usually
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736467
Moved to New Builds and Planning. Please ensure you are posting in the proper sub-forum at all times.
https://linustechtips.com/topic/504652-first-pc-build/#findComment-6736557
