Need help with overclocking
Go to solution Solved by Hackentosher,
Okay, I've only overclocked Intel chips, but I'll give you my process for that:
1. Boot into BIOS
2. Find CPU multiplier (if you want 4.4ghz, set it to 44. It multiplies the base clock, usually 100mhz, by that number to give your final clock)
3. Set multiplier to desired value
4. Boot into Windows and start a stress test or intensive game. If it crashes, go back into the bios and turn up the voltage. I go in 500th's of a volt. Continue to up the voltage until it is stable. If your cooler can't handle the extra voltage, turn down your overclock and voltage and just live with what your cooler can handle.
Good luck!
What cooler do you have?
Hey guys, I'm looking for some tips on how to overclock my amd fx 8350 8-core 4GHz. It's only very slightly bottlenecking my pc and I need some tips on how to bump it up to 4.3 or 4.4 GHz. Thank you guys in advance!
Also follow your post and welcome to the forums
Turn up the multiplier until it reaches 4.4ghz then test with a stress test program, I suggest you have proper cooling first though.
Go here for further information.
http://www.overclock.net/t/1318995/official-fx-8320-fx-8350-vishera-owners-club/56140#post_24699526
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
1. Boot into BIOS
Good luck!
ASU
I tried before, my temps never got above 75C but my pc shut off and I couldn't post. I had to reset the CMOS. Would that be a voltage issue? I thing I turned it up to 1.5V from 1.0V.
Depends on which voltage you're turning up, there are several. VCORE is the one you needed to turn up, however, most 8350's can clock up to 4.6ghz without changing the voltages. Without seeing what you're changing etc I can't help. If you follow that link people more knowledgable than myself will help you.
1. Boot into BIOS
Good luck!
Base clock on AMD is 200mhz, Intensive games do not tell you if you're writing corrupted data to your hard drives, you should always stress test with legit programs made for that purpose.
Chernobyl
Kraken
At 4.2GHz and 3.5V I was able to perform a full 10 minute stress test.
Your motherboard is possibly unable to allow you to overclock. Please visit the link I provided and ask for help in the FX owners forum as I have no experience with your Biostar motherboard but others in there will probably have messed with that board before.
Chernobyl
Kraken
Temps were below 60C and my motherboard is literally the "overclocker" model of the motherboard
At 3.5V on the Vcore??? Teach me your ways! My i5 will reach 90 in synthetic stress tests at like 1.25V at 4.3ghz. If it's stable and it stays cool, then you should be good.
ASU
He means 1.35v, you need to delid that i5 and change the TIM under that IHS. 90c at 1.25v is kind of poor.
Chernobyl
Kraken
