CPU temperatures problem
On AMD systems, the "TMPIN0" temperature reading is usually the more accurate reading for the CPU. Depending on the motherboard it will actually read "CPU" instead of "TMPIN0."
At least, from my experience with two AMD ASUS ROG boards (890FX Crosshair IV Formula + 990FX Crosshair V Formula), it shows the readings as "CPU," and it matches the reading from within the BIOS.
SpoilerPhenom II X6 1090T on ASSU Crosshair IV Formula board (CPU idling in desktop)
Phenom II X6 1090T on ASUS Crosshiar V Formula board
FX-8350 on ASUS Crosshiar V Formula
FX-4130 on a Gigabyte motherboard (another LTT member)
FX-8350 on MSi 990FX Gaming motherboard (another LTT member)
I have images for my A6-3670K as well...but I need to find out where I uploaded them to...
FX don't read temps the same way as FM chips do.
it was not everything on the same time. I' ve tested all on their own and its the same thing.
You need to download the AMD stuff to work out your correct temps.
http://www.tomshardware.co.uk/faq/id-2122665/understanding-temperature-amd-cpus-apus.html
