Super sick build, a good cooler is the Hyper 212 Evo, with the rest of your money you can replace the fans on the heatsink for a push pull configuration?
Edit: Some people are going to recommend a better power supply right off the bat, up to you whether or not you want a better one, I'd recommend a modular one though since you have a window and it would make your PC look a lot more sleeker, tidy..
Edit 2: Friend has that CM mouse and keyboard kit and it works fine.
i5 4590 @ Stock, XFX R9 290!, HyperX Beast 4x8GB  @1600, 850 EVO 120gb, WD Caviar Blue 1TB, , Asrock H97m Pro 4 , Fractal Design Define R4, Windows 10
https://linustechtips.com/topic/504255-first-build/#findComment-6731533
The NZXT S340 has a PSU shroud and covers up all the extra cables. I will add white cable extensions later on.
Thanks for the feedback
https://linustechtips.com/topic/504255-first-build/#findComment-6731564
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($89.88 @ OutletPC)
Video Card: Sapphire Radeon R9 380X 4GB NITRO Video Card  ($233.98 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($63.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($89.89 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($39.87 @ Amazon)
Monitor: Asus VS228H-P 21.5" Monitor  ($119.89 @ SuperBiiz)
Total: $1114.74
Generated by PCPartPicker 2015-12-12 20:31 EST-0500
https://linustechtips.com/topic/504255-first-build/#findComment-6731571
~snip~
Honestly for the price of the 120GB variant of 850 evo it's worth going for the 250 GB instead, it's only like $10 more.
@Savir
Edit: http://www.amazon.com/Samsung-2-5-Inch-Internal-MZ-75E250B-AM/dp/B00OAJ412U
https://linustechtips.com/topic/504255-first-build/#findComment-6731581
Total: $1114.74
Thanks for the recommendations I will look into it.
https://linustechtips.com/topic/504255-first-build/#findComment-6731591
