I'm not sure what power supply I'll need for my build. I was going to go with a Corsair RM550x, but I don't know if it will be enough as I want to watercool my computer.
Here's what I'm going to buy:
CPU: Intel Core i5 6600K 3.5GHz
Motherboard: MSI Z170A Krait Gaming Motherboard
RAM: Kingston FURY 16GB DDR4 2400MHz Memory
GPU: MSI GeForce GTX 970 4GB Video Card
SSD: Samsung 850 EVO Series 250GB SSD
HDD: Seagate Barracuda 3TB
I'm going to have a D5 pump in the case, and about 6-7 fans.
There isn't much limit as to how much it will cost, as I want the power supply to be reliable.
https://linustechtips.com/topic/503797-what-power-supply/
-snip
500-550w unit from:
evga g2,gs,gq, p2, etc. (not nex or evga w1)
any  xfx unit
any  seasonic unit
cooler master v series
any superflower unit
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6725985
500-550w unit from:
any  xfx unit
any  seasonic unit
Only 500-550? So the RM550x would work? I thought I might need more :/
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6725997
for reliability and to carry a 970 card I would go for a 80+gold 650 psu like:  http://www.newegg.com/Product/Product.aspx?Item=N82E16817438054
        http://www.newegg.com/Product/Product.aspx?Item=N82E16817139143
case:"accelerated"Therlmatake VA8000BWS Armor psu:EVGA Supernova G2 750w board:Asus M5A99 FX Pro R.2
cpu:AMD FX 8350 ram:2x8gb Corsair Vengeance Pro 1866mhz gpu:Sapphire Nitro R9 380  4gb
ssd:Samsung 850 EVO 250gb hdd: 2x1tb WD Caviar green cpu cooler: Coolermaster Hyper 212 EVO
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6726014
dont listen to the guy above me.. efficiency does not effect reliability and you dont need 650w.. the rm 550x would work yes
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6726021
I'm not speaking.. I'm typing..
and that's my suggestion..
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6726071
but its wrong... 970 is fine on 500w.. 550w for headroom
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6726143
you are wrong indeed - efficiency has nothing to do with quality
Antec HCG is 80+ bronze yet is several times better than Corsair CS which is 80+ gold
970 and any other single GPU is fine on 500-550W
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6726199
Well that system might use 300W if you intend to set fire to your GPU (so expect like 270W under overclocked load) so wattage isn't a huge issue. An EVGA GS/B2/GQ/G2 would be a good option, although I'd go for a 390 over a 970 any day. You'd still be good on any of those PSUs, 550W+.
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6728461
I wouldn't say many times better but I'm not denying that it IS better.
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6728473
CS uses chinese caps, mediocre build by Great Wall and overall lackluster performance capping out at 40*C
Antec HCG uses all Japanese caps, OEMed by SeaSonic and has excellent voltage stability and caps out at 50*C - is also cheaper
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6728477
still beats the CX series
Also when the CS series gets cheap it becomes a decent option for a budget gaming rig
I don't think the HCG is sold in the US anymore
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6728488
https://pcpartpicker.com/part/antec-power-supply-hcg520m
https://linustechtips.com/topic/503797-what-power-supply/#findComment-6728515
